Re: 12 Volt Conversion
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bob M on May 03, 2000 at 04:42:36 from (192.232.120.194):
In Reply to: 12 Volt Conversion posted by Case on May 02, 2000 at 20:02:03:
Your problem description sounds like you've got a 6 volt coil installed. Recommend you install a ballast resistor (NAPA #13ICR or similar) in the primary before the coil.
Hope this helps!
Post A Followup
: Re: Re: 12 Volt Conversion
