Posted by Andrew Z on February 28, 2010 at 07:49:01 from (64.252.41.103):
In Reply to: Re: Gaskets-Leaking posted by Farmall-H on February 28, 2010 at 06:31:02:
Unfortunately there is no real way to stop the leaking with out replacing the seal, in this case the rear main seal. The only thing that you can try is to add a 'seal stop leak' product to the oil in the engine. I have tried it in the past with a Cub but the leak was to much to stop it. However iv had friends that have used it with some success. If it just leaks a little bit then it maybe a viable option. But the real fix is to fix the seal, anything else is a band-aid.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
