Re: Not IH- Gehl 4640 Engine Issues
Posted by ihjeff on February 28, 2010 at 21:14:32 from (68.115.74.175):
In Reply to: Re: Not IH- Gehl 4640 Engine Issues posted by ihjeff on February 28, 2010 at 21:09:08:
Also, if the pump is out, or weak, would it be able to run a while, or would it just not start? Thanks again- Jeff
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
