Is the pump before the spin on filter a low pressure lift pump or is it actually the high pressure injection pump??? I assumed that since there wasn"t much of a filter before it that it was just a lift pump, and that each injector had its own small high pressure pump (I"m obviously no diesel mechanic). It doesn"t seem like it smokes much when attempting to restart. Did not notice any horsepower decrease, but not saying there wasn"t any, and it will run on a bit of ether, but doesn"t continue to run off of diesel. It has over 2500 hours on it and the pump hasnt been touched. It seems like it is supplying enough fuel pressure thru the filter if it is just a lift pump, but doesn"t seem near enough pressure if it is indeed the high pressure injection pump, though I still think it would have been filtered better before it went to it. Thanks again- Jeff
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
