Re: Not IH- Gehl 4640 Engine Issues
Posted by The tractor vet on March 01, 2010 at 04:44:58 from (75.19.124.251):
In Reply to: Not IH- Gehl 4640 Engine Issues posted by ihjeff on February 28, 2010 at 19:43:45:
What kind of fuel shut down does it have a manual cable or does it shur down with the key switch? If it is a key switch shut down there is where i would be looking as you either have a problem with juice getting to the shut down solenoid or there is a problem inside of it . So i would check and make sure that you have juice at it when it does shut down and if does not then ya need to back track to the key switch to find where you are loosen contact , If you still have juice at the shut down solenoid then the problem is in the solenoid it's self .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
