Re: Not IH- Gehl 4640 Engine Issues
Posted by ihjeff on March 02, 2010 at 04:16:30 from (68.115.74.175):
In Reply to: Re: Not IH- Gehl 4640 Engine Issues posted by The tractor vet on March 01, 2010 at 04:44:58:
Vet-It has electric shut off- I thought that might be the problem, but it still has fuel at flowing out of the return line after the "mini pumps" when turning the motor over after it quits, and it didn't make sense that it would run for a while and then quit, unless the solinoid was over heating or shorting out. But I am going to look at the shutoff again. Thanks!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
