1206 pto problem
Posted by joe 1971 on March 01, 2010 at 16:12:39 from (216.51.206.101):
I got a 1206 that I rebuilt the pto unit. Put all new seals from front to back of unit. New clutch. Oil pump looked good. The pto clutch smoked out before all this. Anyways I cant get over 30 lbs oil pressure. Cant even adjust it. I rechecked the piston seals and were good. I even replaced them again. Could something in the valve be bad. I took off the big nut and pulled up on valve and has down pull on the spring. Id be thankful for any ideas. Joe
