Posted by pete 23 on March 01, 2010 at 17:53:33 from (173.87.0.197):
In Reply to: 1206 pto problem posted by joe 1971 on March 01, 2010 at 16:12:39:
Did you check or replace the teflon seal rings and o-ring on clutch drum and shaft. I always use air pressure when assembling pto before I put the pump assembly on. Air should activate the clutch piston when applied into port that pump supplies oil too,with you pulling on the valve by hand. If not, no need to assemble any farther until you find where leak is. It will not seal 100% but should move the piston with air pressure.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
