Re: farmall h governor still don't work
Posted by jim from az on March 03, 2010 at 11:06:15 from (67.40.93.102):
In Reply to: Re: farmall h governor posted by Curt from MN on March 03, 2010 at 00:23:36:
hi the book says to adjust the rod with the throttle wide open when it's wide open , there is no play.. i don't think that throttle shaft to carb is hanging up it was clean and i could turn the butterfly in carb easy and the shaft turned easy i don't understand what is going on the exhaust manifold is right the valves are right linkage is not hanging up , they're on right .. maybe green is the answer,, i know wash my mouth out with soap
