Re: CNKS-More Governer Questions
Posted by Theman on March 04, 2010 at 04:34:22 from (65.198.133.254):
In Reply to: CNKS-More Governer Questions posted by Formerly PaMike on March 03, 2010 at 18:10:03:
Mike, keep in mind that when the engine is idling there should still a small bit of tension on the spring because the flyweights are still trying to sling out. If the stop bolt won't contact the case, check your rod linkage over the head. It should push down far enough on the governor lever so the spring isn't pushed.
Yes, there is an idle stop screw on the carburetor. It is the one pointing perpendicular to the butterfly shaft and slightly above it.
