Re: MW Hand Clutch
Posted by Andrew Z on March 04, 2010 at 15:31:35 from (64.252.41.103):
In Reply to: Re: MW Hand Clutch posted by Nebraska Kirk on March 04, 2010 at 15:21:33:
Kirk,
thanks very much for the info, looks like the hand
clutch is out of the question for what im going to
be doing with it, dont want to spend big money to
just burn it out.
thanks again
Andrew
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
