Re: MW Hand Clutch
Posted by Nebraska Kirk on March 04, 2010 at 15:21:33 from (207.91.4.216):
In Reply to: MW Hand Clutch posted by Charles E. McNelly on March 04, 2010 at 09:41:07:
Andrew Z said: (quoted from post at 11:41:07 03/04/10) Can a M&W hand clutch hold 60hp or alittle more out of a Super MD without slipping? A friend had one in a MH 44 and it slipped bad when he tried pulling it on a stone boat or trying to pull a 3 bottom plow even in first gear. Im thinking about putting in a hand clutch in my Super MD but dont want to have problems with it slipping. I would be using to do a little plowing and pulling.
Thanks for the help
The owner's manual for the M&W clutches recommends that no heavy pulling be done with an M&W clutch equipped tractor. I would be hesitant to run that much HP through the clutch, especially when plowing or pulling. Very few new parts are available and a limited supply of good used.
I deal in M&W hand clutches and parts and I have only come across one clutch for the Super M/MD. M clutches are pretty common, but in my experience the Super M/MD clutches are harder to find and the major components are different than the M/MD clutch.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
