Posted by john taipale on March 04, 2010 at 18:45:01 from (209.105.184.45):
Had engine rebuilt by reputable engine shop that does top notch work. Put engine back on tractor. Had distributor rebuilt. Placed engine in top dead center. Two notches on flywheel at pointer. Piston in cylinder one visible at top. Also stuck finger in plug hole to verify compression stroke. Put distributor on - lined up correctly. Verified spark from distributor by taking #4 spark plug out and watching for spark on each compression stroke. Made sure new plug wires going to correct cylinder in 1-3-4-2 firing order. Rotor rotating clockwise. Took off distributor cap and removed plug #1 and with finger in #1 cylinder hole watched rotor rotate and compression and rotor position and all appears to be correct. Put the plug back in and dist. cap back on and tried to start. Had sprayed starting fluid in cylinders. Starting fluid in carburetor air intake. Choked, turned on start switch; and no firing! I'm stumped. Any insight will be appreciated. Thanks John :)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
