Re: Re: More H Problems
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill {Antique Acres] on May 03, 2000 at 11:01:29 from (63.162.254.66):
In Reply to: Re: More H Problems posted by The Red on May 03, 2000 at 09:34:53:
I had the same problem with my 49' H. It would run just fine then die after a couple minutes. Turned out the some kids put some shredded carboard in the tank. I doubt that's your problem, but you could have something in the tank causing the same thing. It would let enough gas go through and fill up the carb and gas line, but would not let enough gas go through quick enough to keep it running after the carb and line were drained. If you let it sit 20 minutes it would start up and do the same thing. I would check your tank and make sure nothing is blocking the opening. I would also take your bowl aasembly out of the tank. Sometimes that old pot metal they use on the them gets weak and breaks of and plug the hole up in the aseembly and you won't know until you take it off. Let us know what you find out. Bill {Antique Acres}
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
