Posted by Jeff Z. on March 06, 2010 at 17:47:25 from (74.76.3.113):
In Reply to: Cork Float posted by Tom in Iowa City on March 06, 2010 at 16:45:09:
From the Carburetor Shop:
CORK FLOATS
Many of the less expensive carburetors from the beginning up through about 1940 were originally equipped with floats made from cork. Most of the floats were coated with orange shellac, and then the finish was baked, creating a finish fairly impervious to the gasoline of the day. A few of the manufacturers did not coat their floats, and used a cork material that seemed to work fairly well with the gasoline then being sold.
The gasoline of today cuts orange shellac like a hot knife in butter, and also will permeate the natural cork material!
This poses a severe problem for the restorer. It is not economically feasible to attempt to mass produce brass floats to replace the cork floats. Also, the company producing the poly-nitrofill foam floats has been most un-cooperative unless orders of very large magnitude are placed with them. We are currently machining float pontoons from this substance, to be used with the original float arm.
For those who are independently wealthy, individual brass floats can be made. This also may be a solution for a retired machinist with access to a good machine shop. This is a very time-intensive remedy, expensive if one must pay for the time.
For the rest of us, it becomes imperative to attempt to use a replacement cork (or foam) float, and seal the cork (or foam) against the permeation of the gasoline. The procedure we at The Carburetor Shop are currently using is as follows;
(A) Detach the original brass arm from the original cork float.
(B) Clean the arm (we use a glass beading machine)
(C) Attach the arm to the polynitraphyl pontoon included with this kit.
(D) Submerge the pontoon, and the portion of the arm in direct contact with the pontoon into a product called ‘POR-15’. This product is available from POR-15, Inc, P.O. Box 1235, Morristown, NJ 07962. They have a website at www.por15.com. READ THE DIRECTIONS. ACCORDING TO POR15, ONCE THEIR PRODUCT DRYS, YOU MUST WEAR OFF ANY YOU SPILL ON YOU! I BELIEVE IT!
(E) Remove the float from the liquid and slowly rotate to eliminate any bubbles.
(F) Suspend the float with a suitable hanger, and allow to air dry for 72 hours prior to use.
This procedure seems to be working with the current mixture of gasoline.
If anyone comes up with a better procedure, we would certainly wish to be informed!!!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
