Re: Cork Float
Posted by 440 sixpack on March 07, 2010 at 12:15:32 from (64.179.130.19):
In Reply to: Re: Cork Float posted by Jeff Z. on March 06, 2010 at 17:47:25:
I used clear fingernail polish on the cork float in my Hart Parr, that was almost 2 years ago and still seems to be holding. The trick is to drain the bowl on the carb when you shut it down for the day, that way the float isn"t sitting in gas for long periods of time.
