Re: Oil contamination Farmall M?
Posted by Andrew Z on March 07, 2010 at 16:31:40 from (64.252.41.103):
In Reply to: Oil contamination Farmall M? posted by 3500sport on March 07, 2010 at 16:25:02:
Is this out of the oil bath air cleaner or the
engine oil? if its out of the engine thats most
likely condensation, pretty much from sitting and
not being worked hard enough to burn out the moisture out of the oil. Just change it and run it
check it to make sure the level stays in the run
range.
Andrew
