Farmall wrangler said: (quoted from post at 05:31:51 03/07/10) My uneducated guess is that the 450 injectors would fit your tubes but you might want to make sure you have the 450 injector lines from the pump also. I just did a swap of injectors from a 400 to a 450 and the 450 injector lines attach about an 1/8 of a turn clockwise. sorta at a 45° angle to the plain of the head.
Zactly. The 450 lines are easier to put on/take off, but come in from about the 10:30 position and are a bit longer. They came about with the B pumps, somewhere in the late 400 series I am told.
I would check that measurement. I haven't measured those, but it would be very rare to find bolt holes not on a standard inch based spacing. Not that it should matter as the holes should be slotted a bit anyways, or oversized a skosh. Apply torque while popping will help. You won't get a lot of bang from a slide hammer, which sometimes is not a bad thing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
