Re: MW Hand Clutch
Posted by Bill Schaffran on March 09, 2010 at 10:29:22 from (12.40.191.155):
In Reply to: Re: MW Hand Clutch posted by Nebraska Kirk on March 04, 2010 at 15:21:33:
I bought m&w clutch for my Int H is mising the lever to put in and out would you have that item if so would be all right to call me Bill 507 220 8675 Thanks
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
