Re: Normal use?
Posted by CNKS on March 11, 2010 at 14:17:15 from (216.144.104.128):
In Reply to: Normal use? posted by EKP60 on March 11, 2010 at 12:19:26:
By bushing I assume you mean the piece on top of the steering post that the shaft goes through. That is a common wear point. Don't know if the aftermarket has them or not. Used ones are available, or that one can be repaired. You won't find many drawbar holes that are not worn. The tractor has probably been painted for sale, there may or may not be significant problems with it. Paint is often used to sell, and is meant to detract from other defects.
