Posted by EKP60 on March 11, 2010 at 12:19:26 from (136.234.65.117):
Last fall looked at Farmall 300 4-sale, may go back to look. Tractor all beatified, but steering wheel nut loose and bushing? holding the shaft gone,so that you could move the shaft with the steering wheel 1/4 inch or so..Is it common to have to replace this bushing or shim,or has this girl just seen that much work....draw pin hole not exactly cylindrical. I am not too famalier with the 300. Appreciate your suggestions
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
