Re: Farmall 450 (gas) Generator/Alternator question
Posted by Bob M on March 12, 2010 at 12:42:59 from (151.190.254.108):
In Reply to: Farmall 450 (gas) Generator/Alternator question posted by Tony_Idaho on March 12, 2010 at 12:25:53:
A 1-wire alternator will work. However some (not all...) 1-wire units may have these problems:
1 - Difficulty "turning on" at startup. Engine must be run up to full RPM before the alternator will begin charging. (Once turned on however it will charge fine at idle.)
2 - Tendency to drain the battery if left unstarted for long periods (weeks)
For a couple bucks worth wire and a warning light (or resistor or diode) you can use a standard 3-wire alternator and not risk the above. Also the 3-wire alternator will cost less.
