Fixing a stripped bolt hole
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by RB on May 04, 2000 at 03:29:02 from (12.77.78.102):
On my F-14,one of the holes for the intake manifold is stripped.Im gonna try to run a tap through it and see if that will fix it.It is on one of the holes that goes in the water jaket on the head and when I put water in it leaks.Im also hoping this is the reason for the rough running,vacumm leak.If this doent work,any way I can fix this without drilling and reapping a bigger hole.I dont think I can do that but I may be wrong.Also anybody know what size the bushing in the fan assembly is suppose to be!?Later and TIA!
Post A Followup
: Re: Fixing a stripped bolt hole
