Re: Sleeve retainer goop post #2
Posted by The tractor vet on March 16, 2010 at 14:32:04 from (75.19.124.251):
In Reply to: Re: Sleeve retainer goop post #2 posted by sflem849 on March 16, 2010 at 14:26:30:
I covered that before . you eiher get a oversized sleeve and hone to fit or you bore the block and press in a repair sleeve and re bore it to take the OEm sleeve . Also like i said BEFORE YOU BUY YOUR SLEEVE KITS MIC. the BLOCK and also look for any letters stamped next to the hole for bore classification .
