Re: Six Volt Battery Issue
Posted by old on March 17, 2010 at 09:59:36 from (4.245.7.156):
In Reply to: Six Volt Battery Issue posted by Nifty 350 on March 17, 2010 at 09:34:06:
You say charge to 12 volts that can not happen since a 6 volt battery can not hold a 12 volt charge. Did you put a meter on it to really see what the voltage is??? I'd bet you have done 2 or 3 things to it. #1 boiled the water/acid out. #2 warped the plates. #3 destroyed it because of being low on water and then getting hot by the over charge and now it most likely has warped plates and those mean a shorted out battery in side
