Re: Six Volt Battery Issue
Posted by sflem849 on March 17, 2010 at 13:02:57 from (69.197.84.192):
In Reply to: Six Volt Battery Issue posted by old on March 17, 2010 at 09:59:36:
old said: (quoted from post at 09:59:36 03/17/10) You say charge to 12 volts that can not happen since a 6 volt battery can not hold a 12 volt charge. Did you put a meter on it to really see what the voltage is??? I'd bet you have done 2 or 3 things to it. #1 boiled the water/acid out. #2 warped the plates. #3 destroyed it because of being low on water and then getting hot by the over charge and now it most likely has warped plates and those mean a shorted out battery in side
I concur.
I also would like to say it is impossible to charge it to 12 volts. The number of volts has to do with the number of cells in the battery. It isn't like polarizing a generator/VR.
