Re: F504 clutch question
Posted by TractormanNC on March 17, 2010 at 18:24:43 from (209.42.181.214):
In Reply to: F504 clutch question posted by Machine249 on March 17, 2010 at 17:28:58:
Sounds like you have an adjustment problem. If the clutch engages when the pedal is 1/4 from the floor, there is way too much free play. Check your adjustments again. You want the TA clutch to just barely release when the foot clutch pedal is on the floor. With worn linkage, you sometimes have to tweek the TA clutch from the factory setting to get this to happen.
