F504 clutch question
Posted by Machine249 on March 17, 2010 at 17:28:58 from (76.100.246.141):
I'm having some small problem with shifting gears on my 504. I have the clutch and TA adjusted per the I&T manual and I have double checked the adjustment. The problem is sometimes when I try to shift, I can't move the shifter until I shift the TA. Also, The clutch is fully engaged in the first quarter of the travel and the rest is just play. Basically, is my adjustment out or is my clutch worn out? Thanks in advance.
