Re: Farmall 806 Turning up or down the Power
Posted by komputatek on March 17, 2010 at 21:19:17 from (207.179.223.51):
In Reply to: Re: Farmall 806 Turning up or down the Power posted by DeltaRed on March 17, 2010 at 20:25:05:
There has always been a lot of talk about "turning up the power". There are things to consider before doing this.
Traditionally it means to go inside the diesel pump and turn the delivery pump pressure up. This will give you more power and more fuel consumption. Basically you are allowing more fuel to be metered to the injectors. I would caution anyone considering adding a turbo and "turning the screw" as you will possibly be applying more horse power to the drivetrain than it can handle. Most shops would recommend adding the turbo and leaving the fuel metering screw alone or possibly backing off the screw and reducing fuel consumption thus netting the same same H.P. with less fuel.
I saw all this just to say many tractors have been damaged in the name of more power.
