Posted by Kippster on March 21, 2010 at 07:25:29 from (24.144.197.139):
In Reply to: After market 3-point posted by Dan in Ore on March 21, 2010 at 07:04:11:
to answer your question, yes you can run the 3pt off the belly pump exclusively, but you will have less precise control of the hitch. That spool valve allows the belly pump to run all the time with no risk of damage because the spool valve should be an open center valve. Also, the spool valve may be set up so that the 3pt has down pressure which is handy for backblade work or with a scoop. That spool valve also allows you to run double acting hydro cylinders with a tractor with one way hydraulics, thus making the tractor much more useful. Hope this helps! Kippster
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
