After market 3-point
Posted by Dan in Ore on March 21, 2010 at 07:04:11 from (69.71.182.100):
I bought a 1947 M with an after market 3-point on it. They brought lines from the belly pump to a spool valve mounted on the light bar and then to the 3-point. In order to raise the hitch, you first have to engage the valve from the belly pump and then the spool valve.
My question is. Can I remove the spool valve and run the 3-point directly off of the belly pump valve?
