Re: After market 3-point
Posted by Longknife on March 21, 2010 at 07:47:21 from (70.225.79.16):
In Reply to: After market 3-point posted by Dan in Ore on March 21, 2010 at 07:04:11:
I run the three point cyl directly off of the belly pump on my "H". It has a one way cyl., pull lever it raises and holds, push cyl and it drops. The only problem I had was there is TOO much pressure from the pump and it would jerk the brush hog up and jerk the front wheeks off of the ground. When releasing the pressure it would literally drop the implement to the ground, SLAM!!!! I installed an adjustable valve in the pressure line to slow the flow and it works fine....Ed
