Re: H steering center support- binding
Posted by glennster on March 23, 2010 at 15:45:29 from (99.90.9.153):
In Reply to: H steering center support- binding posted by dep on March 23, 2010 at 13:22:51:
try supporting the tractor under the bell housing instead of the frame rails. then loosen the rail bolts at the rear and at the front and see if you can get a little more wiggle room out of the front end. you may need to pry loose the rails at the front by the bolster to re-position it. sounds like the bolster is tipped back slightly toward the rear of the tractor. loosen the engine mount bolts a couple turns too.
