H steering center support- binding
Posted by dep on March 23, 2010 at 13:22:51 from (98.191.62.25):
When I went to put the H back together after rebuilding the front end, The steering shaft binds in the cast bearing attached to the tank support. It binds at the bottom of the bearing, so you cant shim the support to elimate it (it would need to go down). The shaft is not bent. All original parts. The center support does not seem bent at all. I put jackstands under the frame and unbolted the front end to see if that was bolted on a bit off, but thats not it either. I didnt notice if it was like that before I took it apart. Any ideas?
