Re: A couple of MD questions.
Posted by lbg57 on March 24, 2010 at 17:49:36 from (99.149.119.252):
In Reply to: A couple of MD questions. posted by lbg57 on March 21, 2010 at 17:51:18:
Thanks guys for the info. I read that area of the manual a couple of times to get the torque specs for the injectors and must of glanced over that what says which direction to place the pre cups. :oops: Sorry.
After taking the wire wheel to the cups, I did find the "UP" stamped in them.
I still could use a few pictures of the start rod from the operators platform to the cross shaft bracket & also the under tank bracket for it.
The parts manual shows the rod with the offsets in it but is it a rolling offset or just straight? As with the bracket, mine has a kink/bend in it and can't tell from the parts list if it has one or not. The only somewhat picture of it is in the operators manual and it is not to clear. Thanks.
