Re: A couple of MD questions.
Posted by sflem849 on March 24, 2010 at 19:00:50 from (69.197.84.192):
In Reply to: A couple of MD questions. posted by lbg57 on March 24, 2010 at 17:49:36:
lbg57 said: (quoted from post at 17:49:36 03/24/10) Thanks guys for the info. I read that area of the manual a couple of times to get the torque specs for the injectors and must of glanced over that what says which direction to place the pre cups. :oops: Sorry.
After taking the wire wheel to the cups, I did find the "UP" stamped in them.
I still could use a few pictures of the start rod from the operators platform to the cross shaft bracket & also the under tank bracket for it.
The parts manual shows the rod with the offsets in it but is it a rolling offset or just straight? As with the bracket, mine has a kink/bend in it and can't tell from the parts list if it has one or not. The only somewhat picture of it is in the operators manual and it is not to clear. Thanks.
I'll let it slide this time :D It is really easy to get in a daze when reading the manual and blow past details. I only remember bc I just read it about five times making sure the nozzle body retainers would just pull right out (sort of...) I don't need another bull pinon carrier problem ;)
I will try and get a pic of the rod stuff, but I have to start working now. It is a terrible thing.
