Re: 806 front suitcase weights?
Posted by MeanGene1 on March 26, 2010 at 08:10:25 from (204.14.185.23):
In Reply to: 806 front suitcase weights? posted by Bill47 Perry on March 25, 2010 at 11:56:09:
Man, if I only had the stacks of weights from the old dealership... IIRC, the smaller weights were considered standard size, and nominal 73 lbs, and the larger ones were optional size at nominal 102 lbs. Remember as a kid, you'd say "I can put those on"- then once you could, it became your permanent job LOL. Then gramps said, set 'er up for plowing, I'll be back in a while- which meant blowing the wheels out from 60" to 84" centers. Me at 12, and the old 8N with a Wagner loader, the little IH clamp bolt wrench & 4' of pipe. Actually, the rears were easier than the fronts
Same year I started putting on the 4-row cultivators (2) on by myself- the ones that bolted to the weight bracket holes and then swung in to the sides. After moving the wheels back in to 60" of course
