Some say you can do this without removing the cover. I think much easier (despite the work of removing the cover) if you do. You do NOT have to split the tractor. You can remove the assembly that contains the input gear and bearing from under the bottom of the clutch housing. You will have to remove the hydraulic Lift All unit if the tractor is so equipped. Once the hydraulic unit is out, disconnect the coupling between the clutch and the transmission input shaft. I think you may have to remove the clutch shaft. Can't recall if there is enough room with the shaft left in place. Once you have enough room, you can unbolt the transmission input bearing assembly and pull it out. Then you can get to the 5th gear.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
