Posted by David P. Beasley on March 27, 2010 at 20:41:14 from (146.126.51.51):
Hello, I have a IH 240 Utility that I'm restoring. I've replaced all the bearings in the axles along with seals, gaskets etc. I moved the tractor indoors to the stripping/priming process and I discovered a leal around the clutch shaft. Is there a seal on this shaft?I can't find one on any parts lists I 've seen. Is there a way to stop the leak without tearing the back-end apart again? Thanks, Dave
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
