Re: 240 clutch shaft Leaking
Posted by farmer budd on March 28, 2010 at 10:17:06 from (76.247.153.206):
In Reply to: 240 clutch shaft Leaking posted by David P. Beasley on March 27, 2010 at 20:41:14:
there is a shaft that goes thru to the brake, called the brake pedal shft, there is 2 seals on each side of the tractor,the shaft is only a pivot point for the clutch pedal.
