Re: Farmall 400 Hydaulics
Posted by NEKS on March 27, 2010 at 21:38:23 from (76.4.182.153):
In Reply to: Farmall 400 Hydaulics posted by Matt Weltz on March 26, 2010 at 18:57:48:
Before you put the loader on and it bog down a little, it is probably air in line. It is hard to get out. May have to run it for a while before it picks up. If the suction line has a short piece of hose before the pump, exchange it temporary for a clear hose to see if the fluid is moving at all. Keep moving the levers and turning the steering wheel and it should grab ahold. Then watch clear hose to see if bubbles keep passing in the oil. If never stops you have another leak to look for. Mine always picked up when oil was cold, Not when oil was hot.
