Farmall 400 Hydaulics
Posted by Matt Weltz on March 26, 2010 at 18:57:48 from (208.126.16.132):
Hey guys! Got the Dual 250 loader on my 400 today. Unfortunatley I have no hydraulic function. :( I have never tested the hydraulics on this tractor but the engine would always bog down a little when any of the valve handles were moved. I got the bucket cylinder to tilt once and the main cylinders to lift about 8" and then it started sputtering like low on fluid (was full before loader on). Needless to say I turned the tractor off to check again. Fluid level was fine but now I have no hydraulic function. Engine does not even bog down when the valve handles are moved. Loader came off a working tractor but I did straighten some of the steel lines and replace all of the hoses. Think maybe I just knocked something loose and plugged up something? Any help would be appreciated. Thank you!!!
