200 single front wheel bushings
Posted by couv on March 28, 2010 at 18:04:19 from (209.33.29.72):
Broke it down, right side of axle & bronze bushing seemed good, left side of axle is a bit worn which caused wear in the bushing.
Ideal fix would be replace 2 bushings, 2 seals, and have axle built-up and machined down to spec. Anyone have an idea of costs ?
I need
(2) lock washers #23743D (bend-tab to keep axle nut from backing off)
(2) #364469R91 seal ( C.R.#12124)
(2) #361311R1 bushing
who is my best source ?
