Re: Starting Problem with a 300
Posted by Janicholson on March 29, 2010 at 15:29:26 from (64.61.211.45):
In Reply to: Re: Starting Problem with a 300 posted by rustyfarmall on March 29, 2010 at 11:21:10:
With electronic switching (as in post) there should be no issue with .045 (a hot coil might help, but the existing coil is working (if the wire is pulled out!)
