Re: H died and I can't figure out what's wrong
Posted by Janicholson on March 31, 2010 at 17:56:53 from (64.61.211.105):
In Reply to: H died and I can't figure out what's wrong posted by Zachary Hoyt on March 31, 2010 at 16:36:57:
You may have fowled the two plugs. Clean fuel lines might flow, but if there is crud in the tank where the inlet is located, it will not get to the lines. There is a screen at the fitting at the carb that is also prone to collect rust.
If the fuel comes out as fast as through a small sweetheart soda straw, it should be fine. I have seen trash on top of the needle and seat restricting flow. Check the manifold for tight mounting as well. Jim
