H died and I can't figure out what's wrong
Posted by Zachary Hoyt on March 31, 2010 at 16:36:57 from (74.33.222.166):
I am hoping someone smarter than me can tell me what I may need to do to get my H back to running. I have been using it lately to haul wagons and such and this morning I drove out across three fields to some woods, parked the tractor, went in and cut down some trees. When I got the tractor to drive it in and pick up the wood it was hard to start and seemed to be running on three cylinders most of the time. I went ahead and drove it over to the trees and loaded the wagon. Went to start it again and it would only fire on two cylinders and then died completely. I found that the sediment bowl had a lot of rust in it, I presume maybe from driving across the bumpy fields. I dumped it, cleaned the gas line out, took down the carb, cleaned it as best I could and put it back together and still nothing. The spark is good, the suction on the air inlet is strong. I pulled the plugs, #1,4 were dry and #2,3 were fouled. I'm wondering could I have gotten rust particles somewhere up in the intake, or could the carb have a problem? When I cleaned the carb out I noticed that the slot headed shaft on the bottom front corner of the carb is broken inside, at a point where the seem to be four little holes in the shaft. I'm wondering what that is and whether it could keep the tractor from running? I am sorry this is so long, I'm completely stumped. Any advice will be very much appreciated.
Zach
