Posted by mazemeister on April 01, 2010 at 19:20:14 from (24.188.81.230):
In Reply to: Re: 756 German Diesel posted by Weldon K on April 01, 2010 at 19:00:47:
check easy things first... air filter, etc. probably not fuel filter since you say it runs fine under load, just not at high rpms.
one other thing to consider- i have an 806D with the RD pump, and it would run fine but at high rpms (like 2000+) it would miss, sputter, smoke- turned out to be a chewed up spring in the injection pump. the spring was supposed to return the plungers to take a new charge of fuel, so with it broken, it wouldn't pump enough fuel for high rpms. don't know how your pump works.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
