Posted by Weldon K on April 01, 2010 at 19:00:47 from (98.16.17.89):
In Reply to: 756 German Diesel posted by Clynnt on April 01, 2010 at 18:16:22:
Sounds like a fuel supply problem . Shut off fuel supply to filters. Remove primary filter . Open fuel shut off valve and check for full fuel flow through line. If it is slow ,there is a clog in the short standpipe and shut off valve assembly in the bottom of the tank. (You can blow it out with compressed air but junk will remain in tank.) I would empty tank by siphoning or draining. Then remove shut off valve from tank and clean. If fuel flow was good, change both filters,and vent system properly. If engine still has problem , injection pump most likely needs service.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
