Hi Jim, Does the power steering work OK? If it works OK then the MCV splitter is working OK. The brake system is fed from the return line from the oil cooler. There is a restrictor in the hydraulic line feeding the brake system up at the right side of the battery. Possibly a piece of dirt is blocking the restrictor orifrice. To bleed the brakes properly the hydraulic oil has to be up to operating temperature and tractor running at around 1500 RPM. Another hint, never pump the brakes on this tractor without engine running. The never 84 series have a reservoir to hold hydraulic oil for the brakes when the engine is not runnig.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
