International 574 Brake Problems
Posted by Jim Pallas on April 02, 2010 at 14:40:14 from (71.40.233.217):
I have a 574 with brake problems. Can"t bleed the brakes. I have followed the approved procedure with just a trickle of fluid coming out of the bleeder on one side only. Hydraulic system is full, ps and lift controls work quietly and proberly. No sludge. No crimped lines. I"ve even removed the caps on the tees going into the final drive to check flow. Very little flow out of the MTV valve going to the brakes.
Brakes were great last fall. Parked tractor for the winter and had no hydraulics upon restart. Changed filter, removed pressure spliter valve for initial bleed and all systems worked except brakes.
Help! Can"t figure it out. Bottom line, doesn"t seem to be any pressure anywhere to move the fliud through the system.
